  Cruise control
Cruise control by notwohorns
Started on: 01-04-2014 03:30 PM
Replies: 5 (607 views)
Last post by: notwohorns on 01-05-2014 10:30 AM
notwohorns
Report this Post01-04-2014 03:30 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My cruise control doesn't work. I printed out the test procedures, flow chart, and wiring diagrams from Alldata. Following the test procedures, I found that there is no continuity in the wires between the servo and the controller.The wiring diagrams show two connectors between the two. One would be the firewall but I can not find the other. Would anyone know where the second connector would be?
Total ratings: 290
Report this Post01-04-2014 10:52 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no connection at the firewall. The wires just pass through the bulkhead fitting.
seajai
Total ratings: 51
Report this Post01-04-2014 10:59 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year and engine? The wires between the servo and cruise module first go through C500 which is the large block connector by the battery. From there they pass through the firewall and go through C245 which is located on the left side of the center console down by the gas pedal area. The cruise module is also in that area. I can post the diagram from the Factory service manual if you can tell me Year and Engine.
[This message has been edited by seajai (edited 01-04-2014).]
notwohorns
Report this Post01-05-2014 08:50 AM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. It's a '86 SE with a 2.8 automatic. If you could post the diagram, that would be great. Thanks again
seajai
Total ratings: 51
Report this Post01-05-2014 10:05 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
notwohorns
Report this Post01-05-2014 10:30 AM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the diagrams. They will help a lot.
Thank again
[This message has been edited by notwohorns (edited 01-05-2014).]
