  Engine ground.
Engine ground. by 87FieroSport
Started on: 01-01-2014 04:29 PM
Replies: 7 (226 views)
Last post by: Lou6t4gto on 01-01-2014 07:20 PM
87FieroSport
Report this Post01-01-2014 04:29 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I came to the realization; the head bolts I got do NOT have the ground stud.
So I put them in and didn't realize this until afterwards.
Can I relocate this ground? Where to?
gtoformula
Report this Post01-01-2014 04:33 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can bolt I to anywhere on the engine ... block/heads, etc. Ground path will work anywhere on the engine.
87FieroSport
Report this Post01-01-2014 04:42 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I've been stressing out about that haha, What would possibly be the best option?
trotterlg
Report this Post01-01-2014 04:52 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
An empty hole on the block would be best, any place with an empty big bolt hole. Larry
87FieroSport
Report this Post01-01-2014 05:01 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I just got the A/C compressor bracket bolted to the head again.
Can I run the ground from the head to the A/C compressor where the other ground goes?
Or would I be able to put it under a nut on a stud in the LIM?
Lou6t4gto
Report this Post01-01-2014 05:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I usually just run ALL my grounds to a stud that holds the transmission to the Block, then a 10 gauge from that stud to the Cradle,( engine and trans are separated from the frame/Car by Rubber mounts) and a 10 gauge wire from the engine to the neg battery post. Can't have too many grounds on a computerized car.
DLCLK87GT
Report this Post01-01-2014 06:53 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Again, any large bolt on the block that you can put a ground
strap under without effecting the bolts torque will be fine. Then bolt the other end to the frame.
And 2 seperate straps would be better. One on the AC bracket would be fine.
And the braided straps are better than just a wire. Check your local parts store or eBay.
Lou6t4gto
Report this Post01-01-2014 07:20 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
as long as the engine ends up grounded back to the Body.
