  3800 SC Swap
3800 SC Swap by thumper_64735
Started on: 01-01-2014 12:29 AM
Replies: 7 (799 views)
Last post by: phonedawgz on 01-04-2014 10:55 PM
thumper_64735
Report this Post01-01-2014 12:29 AM Click Here to See the Profile for thumper_64735Send a Private Message to thumper_64735Edit/Delete MessageReply w/QuoteDirect Link to This Post
what would be a fair rate to install a 3800 SC into an 87? It will have the manual, and I will be building the harness. Thanks for the help.
sco77
Report this Post01-01-2014 01:14 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe parts at cost + 50%
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
thumper_64735
Report this Post01-02-2014 01:42 PM Click Here to See the Profile for thumper_64735Send a Private Message to thumper_64735Edit/Delete MessageReply w/QuoteDirect Link to This Post
all other parts are being supplied, basically all i am supplying is the labor
FIEROFLYER
Total ratings: 180
Report this Post01-02-2014 05:41 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I usually charge $2,500 for all the labour on a full swap and that is with me supplying every thing but the engine/tranny, fuel pump and exhaust parts and of course the clutch and fly wheel on manual swaps just to give you an idea. Dan
DARN Cars now open with
mitchjl22
Report this Post01-03-2014 12:39 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did everything myself except exhaust and wiring harness it cost me about 4k - Donor car was 1100 and the exhaust was 800, that was a large chunk of my budget obviously
thumper_64735
Report this Post01-04-2014 11:57 AM Click Here to See the Profile for thumper_64735Send a Private Message to thumper_64735Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thats what I was thinking, around 2000.00 for labor and the owner supplies the parts. Dark, I do have a question for you. What do you charge for a wiring harness, and about how long does it take to get one finished, and can you reprogram the ECM? That is one thing that I don't have the skill or tools to do.
FIEROFLYER
Total ratings: 180
Report this Post01-04-2014 12:19 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I charge $400 per harness when supplied with a 3800SC harness to work with and $450 when I supply one and all my harnesses come with a matching programmed PCM at no extra charge. Dan
Total ratings: 290
Report this Post01-04-2014 10:55 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
