  Did I buy the wrong LCA Bushings? They already have an outer sleeve on them...
Did I buy the wrong LCA Bushings? They already have an outer sleeve on them... by MacGyversMullet
Started on: 12-30-2013 02:37 PM
Replies: 7 (394 views)
Last post by: theogre on 01-01-2014 03:21 AM
MacGyversMullet
Report this Post12-30-2013 02:37 PM Click Here to See the Profile for MacGyversMulletSend a Private Message to MacGyversMulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
My excitement of getting my rusty LCA bushing bolts off came to a screeching halt. I bought some Moog K6163 LCA bushings, but they already have the outer metal sleeve on them...and my old metal sleeves will NOT come off my control arms, no matter what I do. There is just too much rust and I would honestly rather buy a new control arm rather than fighting them for hours with a torch.
I know I have seen some people use these bushings from another thread, but I need another option.
Are there good quality bushings without the sleeves somewhere out there?
Blacktree
Total ratings: 350
Report this Post12-30-2013 03:04 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
As far as I know, all the stock-replacement rubber bushings have metal sleeves. So if you want to install rubber bushings, those old sleeves need to come out. One trick I've seen people use to remove the old bushing sleeves is to crush it with a press or an air chisel. I've also seen people saw them in half with a hacksaw. But the new sleeves will need to be pressed in. If you don't have a hydraulic press, you may want to "farm out" that job to a machine shop. It shouldn't cost much.
That said, urethane bushings usually don't have sleeves. They're meant to be installed into your existing sleeves, after the old rubber is extracted. Of course, the urethane bushings are stiffer than rubber. Some people don't like that. You can buy Prothane urethane suspension bushings from the Fiero Store, or Summit Racing.
MacGyversMullet
Report this Post12-30-2013 03:20 PM Click Here to See the Profile for MacGyversMulletSend a Private Message to MacGyversMulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I decided to get angry with a hacksaw and a cold chisel. I got them out. Just wanted to make sure, since new Fiero parts aren't exactly hanging off of shelves.
Dodgerunner
Total ratings: 323
Report this Post12-30-2013 09:11 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be sure and put something inside the arm frame when you press back in so you don't collapse them to much.
http://www.youtube.com/watch?v=RohLqpUkANw
Steven Snyder
Total ratings: 106
Report this Post12-30-2013 11:32 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rubber bushings are bonded to the inner and outer sleeves. You can't replace them separately.
Report this Post12-31-2013 12:25 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrong. CA bushings are not bonded to outer shell, or both.
Mostly true. Depending on car... Many Rubber bushings are made as whole item, come w/ inner sleeve and outer shell.
Some (a few 88 rear) had inner sleeve only.
See my Cave, Bushings
stickpony
Report this Post12-31-2013 10:30 AM Click Here to See the Profile for stickponyClick Here to visit stickpony's HomePageSend a Private Message to stickponyEdit/Delete MessageReply w/QuoteDirect Link to This Post
you'll need to find a local machine shop with a hydraulic press that can press them out... OR, you can burn them out with a torch and replace the rubber with Polyurethane bushings like i did just requires a propane torch, the bushings themselves, lots of lube, and a rubber mallot or a hammer with a piece of 2x4 to hit against
Report this Post01-01-2014 03:21 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope. If needed, You can even make a press from pieces bought from home depot etc.
Again, See my Cave, Bushings
