  who has installed keyless entry need advice
who has installed keyless entry need advice by jon m
Started on: 12-30-2013 06:42 AM
Replies: 9 (985 views)
Last post by: jon m on 01-01-2014 06:06 AM
jon m
Report this Post12-30-2013 06:42 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi and hope the holidays are treating you well.
I just want to know whereabouts you installed the box - I am thinking of behind the dashboard near to the power door relays on the passenger side but I am concerned that with the box being inside the car would it still be able to receive the signal from the key fob when any of the buttons are pressed ?
all opinions welcomed
jon
85sliverGT
Report this Post12-30-2013 07:03 AM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have mine up under the dash, on the passenger side. Right by the factory door lock relays
jon m
Report this Post12-30-2013 07:36 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you for the quick reply
jon
NetCam
Report this Post12-30-2013 11:08 AM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is under the dash by the steering column, I've never had any problems unlocking the doors from up to about 25 feet away.
bomluuk
Report this Post12-31-2013 01:24 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be honest, I didn't plan very well when I did mine. It ended up being tucked into the dash right in front of the heater core box. I haven't had any issues with it but I'd rather have put it in a more convenient place.
seajai
Total ratings: 51
Report this Post12-31-2013 04:27 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a spot on the passenger side of the center tunnel where the amp lives if the car came equipped with the performance sound system. If you don't have performance sound, there is an empty spot that is the perfect size for a RKE module. Just pull back the carpet and the plastic inner piece, there is a hump molded into the plastic piece. That's where I put mine.
[This message has been edited by seajai (edited 12-31-2013).]
yellowstone
Total ratings: 250
Report this Post12-31-2013 06:41 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is on the steering column.
Neils88
Total ratings: 56
Report this Post12-31-2013 06:44 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
It works wherever you put it in the car. Find a convenient spot that allows you to secure it properly. Under the dash, close to the fuse box is commonly used as the best spot.
smartaxel
Total ratings: 83
Report this Post12-31-2013 11:11 PM Click Here to See the Profile for smartaxelClick Here to visit smartaxel's HomePageSend a Private Message to smartaxelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right under the steering column, zip tied actually. Had no issues with it there and it was convenient to install
jon m
Report this Post01-01-2014 06:06 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for all your help guys - I think I might put it where seajai has suggested in the passenger area
thanks again and happy new year
jon
