  windshield wipers & AC134a & fiero dash stripped bolt repair
windshield wipers & AC134a & fiero dash stripped bolt repair by uhlanstan
Started on: 12-29-2013 02:09 PM
Replies: 0 (104 views)
Last post by: uhlanstan on 12-29-2013 02:09 PM
uhlanstan
Total ratings: 427
Report this Post12-29-2013 02:09 PM Click Here to See the Profile for uhlanstanSend a Private Message to uhlanstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
$ 7 Anco 31 series wipers have proven superior to expensive brands in consumer reports
rural king ,com has 134a12 oz cans for $5,, great if you need a few cans
when you remove the fiero dash the large spiral bolts (name unknown) screw into plastic
& often are stripped ,, there is a next larger spiral bolt used on the fiero,, they look to big to thread
into the old holes but they work & do not tear up/ruin the holes these are the bolts that go thru the
thin metal plate into steering column, & the lower big spiral bolts that hold the dash ,,use care & just screw them in
you can also thread a 5/16 tap into the holes to rethread the plastic , this works much better than I expected very well,,I put a little grease on the bolt & it went in easy,held tight
the steering column holes are open at the bottom
do not install lower cover untill you set panel "facia trim plate" in place
