  windshield wiper arm's removel, how?
windshield wiper arm's removel, how? by georgie
Started on: 12-28-2013 11:44 PM
Replies: 7 (723 views)
Last post by: theogre on 12-31-2013 03:41 PM
georgie
Report this Post12-28-2013 11:44 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need to remove windshield wiper arm's to paint them. What is a good what to do it with out f...ing them up.
Fiero84Freak
Report this Post12-28-2013 11:54 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have to lift them up slightly and put a small rod into the hole near the base in the arm to get them off. Lift the arm, look at that circular hole, and lift it into a position where you can see clearly through the hole. Now insert a small rod (I use either a coat hanger rod or a thin hole punch) inserted into the arm. Now pull up on the wiper arm assembly and it'll come off.
It can be a bit of a you-know-what trying to do it the first time around, but it WILL come off.
georgie
Report this Post12-29-2013 12:12 AM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great! I Knew there had to be a right way to do it. Thank's
Bruce
Report this Post12-29-2013 03:23 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Buy a whole new arm assembly, since the removal and installatation are much easier. The stock windshield wiper assembly is a pain.
georgie
Report this Post12-29-2013 09:44 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya, thay do suck. Good idea Just may do that.
zmcdonal
Report this Post12-29-2013 09:54 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I always used a couple of small Allen wrenches that will slip through the holes, once I found out how they come off it took just a couple minutes to have them both off.
[This message has been edited by zmcdonal (edited 12-29-2013).]
raysr11
Report this Post12-31-2013 01:03 PM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post12-31-2013 03:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Windshield Wipe
