  circulating problem
circulating problem by krum
Started on: 12-21-2013 07:34 PM
Replies: 3 (132 views)
Last post by: krum on 12-24-2013 10:33 PM
krum
Report this Post12-21-2013 07:34 PM Click Here to See the Profile for krumSend a Private Message to krumEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 2.5 it seems to have a block somewhere I believe. I started it after about 15 minutes I noticed coolant spraying out the side of the intake manifold (no its not the gasket its the manifold itself). I am going to get a new one in the morning what could be the the cause of this problem. The car has been sitting a long time.
katatak
Total ratings: 82
Report this Post12-22-2013 12:20 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
No Flow - check the coolant tubes under the car - usually are crushed right where they turn up to go to motor on each side. Just ahead of the rear wheel wells. Manifold may be cracked?
krum
Report this Post12-22-2013 12:23 PM Click Here to See the Profile for krumSend a Private Message to krumEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced the pipes under the car the intake does have a pinhole in it that is spraying coolant
krum
Report this Post12-24-2013 10:33 PM Click Here to See the Profile for krumSend a Private Message to krumEdit/Delete MessageReply w/QuoteDirect Link to This Post
update i took off my old intake manifold and the tube that goes into it was almost clogged solid i am putting the new intake manifold on tomorrow and hoping that i solved the problem
