  excessive oil consumtion
excessive oil consumtion by donuteater306
Started on: 12-20-2013 04:53 PM
Replies: 6 (149 views)
Last post by: donuteater306 on 12-20-2013 07:48 PM
donuteater306
Report this Post12-20-2013 04:53 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stock 87 GT. One quart every 600-700 miles! What is going on!? I just past SMOG with flying colors. Engine is not smoking (even at start-up). I went around the engine with a good flashlight...no leaks (little seepage around the oil pan but no drips). Only two possibilities that I can think of...Burn it, or leak it!
I pulled all 6 spark plugs, they have a normal tan color to them with no build-up. Valve guides replaced about 25k ago.
Im using regular 5-30 oil, not synthetic. Where is it going?
Total ratings: 466
Report this Post12-20-2013 05:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe you've got a neighbor siphoning your oil?
donuteater306
Report this Post12-20-2013 05:27 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL!
rbell2915
Report this Post12-20-2013 06:46 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine burns a quart every 1500 miles.
Look on the bright side, at least it's a continuous oil change!
trotterlg
Report this Post12-20-2013 07:19 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think it is that bad, bet switching to 10-40 woul get you to about a quart in 1,500 miles. If it runs good I would buy a case of oil for a Chirstmas present for it and be happy. Larry
deceler8
Report this Post12-20-2013 07:29 PM Click Here to See the Profile for deceler8Send a Private Message to deceler8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I always try to use NAPA full synthetic 15W-50...reduces oil consumption to darn near zero in my Duke with 150,000 miles.
Seems like 5W-30 just goes right through it.
donuteater306
Report this Post12-20-2013 07:48 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's just strange to me that it went from almost no loss at 2-3k miles to this. I wonder if my PCV isn't working right.
