  Is there a gasket on the exhaust's y-pipe, exit side?
Is there a gasket on the exhaust's y-pipe, exit side? by MacGyversMullet
Started on: 12-19-2013 11:01 AM
Replies: 6 (459 views)
Last post by: MacGyversMullet on 12-20-2013 01:15 PM
MacGyversMullet
Report this Post12-19-2013 11:01 AM Click Here to See the Profile for MacGyversMulletSend a Private Message to MacGyversMulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a generous leak from the y-pipe connection, on the exit side, right below the O2 sensor. Is there a gasket at that connection? Anyone know the correct part number? Could it be this? http://www.summitracing.com.../pontiac/model/fiero
I tried searching, but every thread is about the manifold gaskets
Blacktree
Total ratings: 350
Report this Post12-19-2013 01:01 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, there is a donut-shaped gasket at that connection. The one in your Summit Racing link looks like that gasket.
Lou6t4gto
Report this Post12-19-2013 01:18 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I "remember", it a "STEEL" Doughnut that is held in between the 2 pipes with a bolts with a Spring on them.
uhlanstan
Total ratings: 427
Report this Post12-19-2013 02:30 PM Click Here to See the Profile for uhlanstanSend a Private Message to uhlanstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is a fiber donut gasket ..may still be available from the Fiero store ,a little bit more than rockauto
you can also get it from some auto parts stores
if in doubt order from the fiero store
#52794
$10.95
just go to fierostore.com to check out this part
rock auto & Fiero store are as good as it gets for internet orders
Fiero store has the edge in customenr service
[This message has been edited by uhlanstan (edited 12-19-2013).]
lateFormula
Report this Post12-19-2013 06:55 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The correct gasket for the Y-pipe flange is the Fel-Pro 60650. The Fel-Pro 60538 is the correct size, but it has a steel sleeve in the ID that has to be removed before used on the Fiero Y-pipe. Nine out of ten times the steel sleeve will come out cleanly, but sometimes the steel sleeve is bonded to the gasket. When that happens attempting to remove the sleeve will at least deform the gasket, at worst split the gasket
Total ratings: 463
Report this Post12-19-2013 10:58 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I was doing some work on mine, I went to Advance and picked up a couple of spare donuts. They were made out of whatever semi-soft fiber they're usually made of. I also bought an identical size/shape donut made out of solid aluminum.
I ended up using one of the fiber ones.
Praise the Lowered!
MacGyversMullet
Report this Post12-20-2013 01:15 PM Click Here to See the Profile for MacGyversMulletSend a Private Message to MacGyversMulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help! Glad I asked before ordering the one with the steel sleeve in it.
