  4t65e HD shift
4t65e HD shift by Lou6t4gto
Started on: 12-17-2013 04:23 PM
Replies: 4 (293 views)
Last post by: darkhorizon on 12-18-2013 02:59 PM
Lou6t4gto
Report this Post12-17-2013 04:23 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
on a 4t65e HD Trans, is there a way, such as using a corvette SERVO to make 1-2nd shifts "crisper" ? (other than a full "Shift kit"). Also, would I be "better off" rebuilding the 1 I have (170K) or buying a bone yard unit ? kit runs about $225, bone yard, don't know "WHAT" I end up with ?? Opinions?
nosrac
Total ratings: 50
Report this Post12-17-2013 05:56 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shifting can be programmed, talk to your tuner. I would rebuild the trans if it is NOT in good running order as the one you purchase may be in worse shape than the one you have.
I would assume your's has been rebuilt before.
Lou6t4gto
Report this Post12-17-2013 07:09 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no, this thing has NOT been rebuilt, from the fluid, I'm sure it hasn't got much left. That's why I'm thinking of doing it.(Really good Video's online of how to, all I need are the "special TOOLS.) The ECM Can be" programmed" to have a "crisper" 1-2 shift ?
nosrac
Total ratings: 50
Report this Post12-17-2013 10:25 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, by tweaking line pressure, shift time, torque settings, and shift points. If you have a performance shift button then you can toggle the aggressiveness settings.
If you do NOT have the button then you can make the normal and performance options the same.
darkhorizon
Total ratings: 451
Report this Post12-18-2013 02:59 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
a "full" shift kit is a few shims in the shift pressure accumulators in the valvebody.. its a 40 minute project from start to finish.
