  car dies at idle, keeps running if I Rev the throttle
car dies at idle, keeps running if I Rev the throttle by blacknblue
Started on: 12-13-2013 04:01 PM
Replies: 3 (151 views)
Last post by: blacknblue on 12-15-2013 07:41 PM
blacknblue
Report this Post12-13-2013 04:01 PM Click Here to See the Profile for blacknblueSend a Private Message to blacknblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
like the subject says, 87 Duke five speed, wants to die at idle in neutral will stay running if I give it done gas though. any thoughts?
Report this Post12-13-2013 04:34 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bad gas or a slight restriction in the injector will do that. Low fuel pressure may do that.
[This message has been edited by Gall757 (edited 12-13-2013).]
Shonyman32
Report this Post12-15-2013 07:07 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump. I have a similar problem waiting to see what everyone says.
blacknblue
Report this Post12-15-2013 07:41 PM Click Here to See the Profile for blacknblueSend a Private Message to blacknblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
update: I think it was an issue with my IAC. When I rebuilt the top end, I accidentally routed a wire bundle too close to the accessory belt and it sawed through a solid blue wire, which I was told was for the IAC. Like a dummy, I took my sweet time repairing it. I finally pig tailed a repair wire there, and it seems to have fixed it for now. I really need to solder it and put in some heat shrink butt splice connectors, but clearance there is pretty tight and I don't think I can get a conventional set of crimpers in there.
