  Cold Air Intake For 2.3 Quad 4 motor?
Cold Air Intake For 2.3 Quad 4 motor? by Dre13Style
Started on: 12-12-2013 10:48 AM
Replies: 8 (327 views)
Last post by: Custom2M4 on 12-14-2013 02:28 PM
Dre13Style
Report this Post12-12-2013 10:48 AM Click Here to See the Profile for Dre13StyleSend a Private Message to Dre13StyleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wondering if anyone has some experience with a cold air intake for a Fiero that has a Quad 4 2.3 motor in it.
I feel as though my car is starved for air and figuring a simple intake may help. Any links, DIY pics, items for sale would be super helpful.
kikinz24
Report this Post12-12-2013 11:33 AM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is the intake setup to the factory location? And what makes you think its starving for air?
Dre13Style
Report this Post12-12-2013 11:43 AM Click Here to See the Profile for Dre13StyleSend a Private Message to Dre13StyleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure If I know how to post pictures on here.
It idles a bit ruff, I have done plugs, the boot and all that crap. If I could compare it to a human, just sounds like its struggeling to breath
it has a hesitation to it.
rogergarrison
Total ratings: 551
Report this Post12-12-2013 12:06 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieros have a cold air intake from the factory...better than any aftermarket one. Only time youd need to get more air is for a big v8.
kikinz24
Report this Post12-12-2013 12:35 PM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
Take the idi cover off and pull the coils off. check the springs under the coils they short out. And a weak coil will cause a rough idle.. I built a quad4 sky high and have probablt encountered each possible problem they can have. Also did you build the motor or know who did. If so did they play with the cams at all.. ?
[This message has been edited by kikinz24 (edited 12-12-2013).]
Dre13Style
Report this Post12-12-2013 12:55 PM Click Here to See the Profile for Dre13StyleSend a Private Message to Dre13StyleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't build this frankenmachine. I got it from a guy who had it in storage for about 10 years. Car has under 40k on the body. I picked it up for $460 not a stop of rust. Oh sooooo clean undercarriage. A company in Colorado had done the swap. The owner had it shipped from Colorado to Massachusetts and couldn't get it to pass inspection. It had no E-brake set up and the shifter cables were busted. He had ordered a new cable but never could get the right one. Its a 5spd car, idk if that also came out of the beretta. I think oddly enough I ended up with the 4speed shifter cable to remedy it. I put a few thousand miles on plus a paint job/ebrake, brakes/rotors,clutch, alternator and the usual from time sitting things. Runs great just seems a bit boggy at times. I am also reading that possibly the IAT sensor could be in a poor location???? Not that I know where it is right now
KurtAKX
Total ratings: 128
Report this Post12-13-2013 10:37 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the check engine light work?
For example, key on, engine off, does it illuminate?
Dre13Style
Report this Post12-13-2013 10:44 AM Click Here to See the Profile for Dre13StyleSend a Private Message to Dre13StyleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The check engine does seem to work. I know once in a rare blue moon it will come on mid way through a drive. Next time I start the car its no longer on though.
Custom2M4
Total ratings: 114
Report this Post12-14-2013 02:28 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
If the air filter is clean, it won't be struggling because of the intake. Have the codes checked, becuase it might be a sensor causing your issue.
