  Plastic on Oil Control Ring
Plastic on Oil Control Ring by smmilke
Started on: 12-06-2013 02:49 PM
Replies: 2 (106 views)
Last post by: Gall757 on 12-06-2013 08:11 PM
smmilke
Report this Post12-06-2013 02:49 PM Click Here to See the Profile for smmilkeSend a Private Message to smmilkeEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the new oil control ring spacers I got there are two plastic blocks at each end. The instructions say to be sure these butt against each other, but I am not sure if I'm supposed to leave the plastic bits on when I install the pistons. It seems like they would melt and cause a problem. Couldn't find a definitive answer for this on the web, any ideas?
*EDIT* After a little more research I was able to find an answer. Sounds like you keep the plastic bits on when you install the rings. They are there to keep you from accidentally overlapping the ends of the spacer ring.
[This message has been edited by smmilke (edited 12-06-2013).]
Lou6t4gto
Report this Post12-06-2013 07:53 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ABSOLUTLEY Leave them ON !
Report this Post12-06-2013 08:11 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Must be a high temperature plastic....
