  Power Window Stuck
Power Window Stuck by dallasreese
Started on: 12-02-2013 11:30 AM
Replies: 2 (568 views)
Last post by: dallasreese on 12-02-2013 11:58 AM
dallasreese
Report this Post12-02-2013 11:30 AM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well...Ive checked the power to the window motor on my 84 Fiero and have discover that power is getting to motor plug. Do any of you guys know anything else I need to check prior to changing out motor. Are there any good videos or links that will guide me? Thanks.
Dallas
jaskispyder
Total ratings: 205
Report this Post12-02-2013 11:33 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the door panel off, find the plug to the motor and connect up a battery (+ to one terminal and - to other.... switch to change direction of motor). If the motor doesn't move, it needs to be pulled.
Here is my writeup for adding power windows, this may help: http://www.michiganfieroclub.com/files/power.pdf
dallasreese
Report this Post12-02-2013 11:58 AM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes...I will have to pull motor and the link is just what I need. Thanks..Dallas
