  axle output seal
axle output seal by mark schuyler sipe
Started on: 11-27-2013 09:44 AM
Replies: 15 (703 views)
Last post by: mark schuyler sipe on 12-05-2013 09:51 AM
mark schuyler sipe
Report this Post11-27-2013 09:44 AM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an '84 pace car with 62,335 miles. I've been storing it for awhile. I'm gonna do some things to it and start driving it next year. Since it's been in storage it developed a leak at the axle output seal on the driver's side. I replaced it with a 3543 seal from oreilly's. I assume they gave me the right seal. It looks identical to the original. Well, it leaks too. I cleaned all surface rust off the shaft and used grease when installing it. The transmission case looked fine where the seal goes in. Looks like it is leaking where the shaft and seal contacts. It didn't leak when I bought it in March,2011 and have driven it very, very little. The fiero factory emailed me and said it could be worn differential carrier bearings. To me , this seems unlikely with only 62,335 miles. Any opinions?
Report this Post11-27-2013 09:56 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bearing and/or axle have problems.
Seal install w/o sealer. See my Cave, Axle
Report this Post11-27-2013 09:57 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
Grab the axles and push-pull with some force. If they click a little that is OK, but if you can see movement over .050" or so.....the bearings are worn.
jaskispyder
Total ratings: 205
Report this Post11-27-2013 10:07 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm, seems unlikely that yow would have a mechanical issue, but it could happen. What type of oil do you have in the tranny?
mark schuyler sipe
Report this Post11-27-2013 10:19 AM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put in 3 quarts of 5w30, not synthetic. I put this seal in a 2 or 3 months ago. As I remember, there was no outward play on the shaft. I used a ball joint separator(fork) and I remember it being very tight when popping it loose.The tool worked good. I made my own driver that let me get out past the strut to drive the seal in. It seemed everything went together as it should. Oh yeah, I didn't drive it after I put the seal in. Just drained the oil back out. Didn't want oil on the floor. Would storing it on jack stands have anything to do with it, since the suspension is unloaded?
tebailey
Report this Post11-27-2013 06:21 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did you install the seals? I had to redo mine when they leaked. Checking them I saw that I did not get them seated tight. Also had a few rust pits on the drivers side axle. Made sure the second set was seated and replaced the axle. All is fine now. Also put in syncromesh fluid. Shifts like a dream.
[This message has been edited by tebailey (edited 11-27-2013).]
mark schuyler sipe
Report this Post11-30-2013 09:48 AM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I guess i'm just gonna redo it. Maybe try sealer instead of grease. I've never done that before and I've never had one leak before. My shaft had rust pits. I just wire-wheeled the whole shaft. It looks like new. Maybe I'll get a new shaft too. Thanks for the replies.
mark schuyler sipe
Report this Post11-30-2013 10:04 AM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
mark schuyler sipe
Member since Nov 2013
One more thing for now. Has anyone used the fiero store's axle stabilizer bearing and seal? Are they worth $159.95?
Report this Post11-30-2013 10:55 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
the short answer is NO.
Report this Post11-30-2013 11:44 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
They almost always leak since the seal is less flexible than the stock seal. Plus if you really want then you can get them for both sides for about $50 elsewhere.
Report this Post11-30-2013 11:50 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put in 3 quarts of 5w30, not synthetic. I put this seal in a 2 or 3 months ago. As I remember, there was no outward play on the shaft. ... Would storing it on jack stands have anything to do with it, since the suspension is unloaded?
out/in = axial play.
side play = radial play.
Seal doesn't care much about axial play but Too much radial play will make new seals leak oil.
store when axle "unloaded" trans doesn't care.
Not at any price. They are a band-aid fix and often causes other problems, including axle failure. Search PFF archives.
FieroNate
Report this Post12-01-2013 12:10 PM Click Here to See the Profile for FieroNateClick Here to visit FieroNate's HomePageSend a Private Message to FieroNateEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wire brushing isn't good enough for an axle seal surface. They need to be polished with an equivalent surface finish of RMS 16 or better. Otherwise they will leak. I can tell you I had a 4T60 that was GM overhauled but had a leaking axle seal after 10K miles. Upon investigating it turns out someone forgot to put the axle bushing back in it. Replaced the housing with a used one that had the bushing in it, replaced the wheel seal and put it back together. No leaks since.
If there is any pitting on the shaft it needs to be polished or use a Redi-sleeve/speedi-sleeve to repair.
http://www.skf.com/group/pr...di-sleeve/index.html
http://www.timken.com/EN-US...ges/redisleeves.aspx
Rock Auto lists them under Transmission -> output shaft repair sleeve
For 1985 2.8L 4 speed manual they list:
Timken Part # KWK 99139
National Part # 99139
SKF Part # 99138
I suspect you have a worn bearing or your shaft is very worn. Fix either or both of these and the leak hold stop.
[This message has been edited by FieroNate (edited 12-01-2013).]
hobbywrench
Report this Post12-01-2013 05:08 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axle seals are delicate. Inserting and removing the axles often ruins seals, not just Fieros. The neoprene can be cut by splines. The circular seal spring can be stretched by the weight of the axle end during withdrawal and insertion. Take the load off with a support or second set of hands. The RMS (surface finish ) of the seal journal must be correct, without nicks. Axle removal is probably the biggest source of problems. You normally cannot see the damage. My 88 came from the factory with a leaking out put seal.
qwikgta
Total ratings: 84
Report this Post12-01-2013 05:16 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hate axle seals.
RJ
mark schuyler sipe
Report this Post12-05-2013 09:50 AM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the good info. everyone.
mark schuyler sipe
Report this Post12-05-2013 09:51 AM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
mark schuyler sipe
