Update System
  need a pic of where the plug wires go
need a pic of where the plug wires go by Lou6t4gto
Started on: 11-25-2013 01:59 PM
Replies: 3 (156 views)
Last post by: Lou6t4gto on 11-25-2013 06:16 PM
Lou6t4gto
Report this Post11-25-2013 01:59 PM Click Here to See the Profile for Lou6t4gtoClick Here to Email Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
almost done with my 3800SC, the COILS have no designation on them as to "Which tower" is for which Plug. I've seen other cars have the # of the cyl on the coil, these do not. and, I think I read on a post somewhere , that I "Can" leave the coil in it's "original "mounting spot, If I "turn it" ? Thanks
lateFormula
Report this Post11-25-2013 05:54 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unscrew the individual coils from the mounting bracket and look at their underside. It's been my experience with these DIS coils that they are typically stamped on both the top and bottom with the intended cylinder number.
sco77
Report this Post11-25-2013 06:03 PM Click Here to See the Profile for sco77Click Here to Email sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't understand exactly what you are asking, kind of poorly worded. Anyway, all the coils are the exact same regardless of what number is on the coilpack, the only thing that matters is where the coil is on the ICM.. Let's call the end of the ICM with the wire connector the bottom (since that is usually the bottom on the original cars engine).. From bottom to top it goes 1/4, 2/5, 6/3
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
Lou6t4gto
Report this Post11-25-2013 06:16 PM Click Here to See the Profile for Lou6t4gtoClick Here to Email Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The numbers over the coil towers in the picture, there are no numbers on my coils( and no plug wires at the time) so I was not sure where the plug wires went. Thanks. any explanation of HOW the coil pack has to be "Turned" to clear the deck rail ? thanks again
