  12v Ignition Source
12v Ignition Source by Jecklen16
Started on: 11-24-2013 08:31 AM
Replies: 3 (160 views)
Last post by: Jecklen16 on 11-24-2013 11:12 AM
Jecklen16
Report this Post11-24-2013 08:31 AM Click Here to See the Profile for Jecklen16Send a Private Message to Jecklen16Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm hooking up an aftermarket coolant fan relay with it's own temperature sensor and temp. adjustment. I know where I need to connect everything except for a 12v ignition source... I have no idea where get that from. Any ideas?
steve308
Total ratings: 58
Report this Post11-24-2013 10:09 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Couple of 12V connections in the fuse box --- one hot one switched or you can run a fuse tap.
Report this Post11-24-2013 10:11 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The old wiring for the fan?
Jecklen16
Report this Post11-24-2013 11:12 AM Click Here to See the Profile for Jecklen16Send a Private Message to Jecklen16Edit/Delete MessageReply w/QuoteDirect Link to This Post
The only old wiring i see is 4 wires going to a connector that used to go to the fan relay... A thick black and thick red on either side with 2 wires of unknown color in between.
