  3800 swap and gauges question
3800 swap and gauges question by mmeyer86gt/gtp
Started on: 11-22-2013 11:22 PM
Replies: 7 (749 views)
Last post by: jscott1 on 11-24-2013 05:58 PM
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-22-2013 11:22 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
so i am putting in a 3800 and still amassing parts and i thought how easy it would be to put a fire bird gauge cluster in a fiero if the cluster is set up to run those gauges already any one else under that impression. repin my wires and plug it into the cluster and whalah it works ???? am i just thinking it will be too easy?
Total ratings: 290
Report this Post11-23-2013 12:19 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd do the engine swap first and then the dash swap later. There is no advantage in doing both at the same time, however there is a disadvantage. If you do both at the same time and something doesn't work you won't know if it is the engine swap or the dash swap.
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-23-2013 01:06 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
got it. on the swap the engine will be running correctly before anything happens i am just looking foward. like does the computer need special programming for the firebird gauges?
Total ratings: 290
Report this Post11-23-2013 12:28 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fuel tank sender sends the signal that the gas gauge. The oil pressure gauge sender sends the signal that runs the oil pressure gauge. On the 3800 the part known as the 3 wire coolant temperature sensor is actually a combo unit consisting of a 2 wire CTS (that runs to the computer) and a separate temperature gauge sender, which is wired to the temperature gauge. So none of these senders(sender half of the combo unit) has connection to the computer.
The 3800 computer controls the alternator. The computer thus has a wire that runs to the 'charge' light. This is a simple on/off light.
The voltage portion of the "alternator" gauge just runs off of the cabin voltage.
The 3800 computer also has an output to run the TEMP light. This also is a simple on/off light. The PCM is programmed for the temp that light comes on at.
There is no programming the ECM/PCM has that runs either the stock or Firebird gauges. They simply just run by being electrically connected to their senders.
[This message has been edited by phonedawgz (edited 11-23-2013).]
fierocarparts
Report this Post11-23-2013 12:50 PM Click Here to See the Profile for fierocarpartsSend a Private Message to fierocarpartsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds similar to the 3900 LZ9 harness I'm doing. Be sure to use the V-6 harness as it is easier than trying to adapt to L-4.
You may want to check with JScott seeing how he does a lot of the FB dashes.
FIEROFLYER
Total ratings: 180
Report this Post11-23-2013 01:00 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure on the fire bird gauges but one problem using newer gauges is the feeds to the gauges them selves are often data line fed instead of individually fed and some cars the fuel sender feeds the PCM then the PCM works the fuel gauge. Again not sure how the fire bird does this but some thing to watch for. Dan
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-23-2013 07:02 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
i was planning on cutting my fiero connectors that go into the harness and take come c203 connectors and make a harness connection from 2 of those because they are easy for me to get and easy to plug and unplug than the connectors that plug into the gauges.
jscott1
Total ratings: 415
Report this Post11-24-2013 05:58 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
No need to reinvent the wheel when a plug and play harness for the Firebird gauges has already been developed...
