  Rocker Panel repair
Rocker Panel repair by 4thfiero
Started on: 11-19-2013 08:15 PM
Replies: 6 (577 views)
Last post by: flimbob on 11-21-2013 06:40 AM
4thfiero
Report this Post11-19-2013 08:15 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know what size rivets and what KIND of rivets i will need to attach my 2 rocker panels? 88 fiero gt
Tha Driver
Total ratings: 204
Report this Post11-19-2013 09:21 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
1/4" aluminum. Requires a LARGE rivet gun. You can use bolts along the bottom to make it easier to take off next time.
EDIT: Some folks use plastic rivets. Requires a special SMALL rivet gun.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
[This message has been edited by Tha Driver (edited 11-19-2013).]
4thfiero
Report this Post11-19-2013 11:36 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks man!
4thfiero
Report this Post11-19-2013 11:38 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
4thfiero
Member since Oct 2012
what kinda bolts???
Custom2M4
Total ratings: 114
Report this Post11-20-2013 08:56 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can weld nuts onto the skirt support and use bolts.
Tha Driver
Total ratings: 204
Report this Post11-21-2013 03:23 AM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found some trick allen head black bolts at Fastenall. 1/4" x 1" bolts, with flat & lock washers on the back. No need to weld on the nuts. Make sure they don't dent the cooling tubes when you install them. Bolts along with plastic rivets in the top part (under the tabs in the step plate area) will make them much easier to remove in the future.
~ Paul
aka "Tha Driver"
flimbob
Report this Post11-21-2013 06:40 AM Click Here to See the Profile for flimbobSend a Private Message to flimbobEdit/Delete MessageReply w/QuoteDirect Link to This Post
