  speedo pegged 120 , after dielectric grease coil + icm connections
speedo pegged 120 , after dielectric grease coil + icm connections by Chris-Winfield
Started on: 11-19-2013 04:59 PM
Replies: 9 (467 views)
Last post by: Chris-Winfield on 12-04-2013 03:54 PM
Chris-Winfield
Report this Post11-19-2013 04:59 PM Click Here to See the Profile for Chris-WinfieldSend a Private Message to Chris-WinfieldEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I decided to put some dielectric grease on my ignition components , after doing so my rpm gauge and speedo were not working , So I took loose my coil connections and wiped the excess grease off that was on the face of the plug from apparently putting too much on the tiny connections.
RPM's came back , speedo still pegged at 120 , so I did some more cleaning with a qtip of the male and female plugs I used the dielectric grease on , my speedo is still pegged and I was just out messing with my car yesterday and my speedo was working normal , I am sure I would have noticed if it wasn't.
Which of the connections do I need to focus on cleaning better? The needle jumps when first started but stays pegged.
I put some of the dielectric grease on the AIC valve , each of the 2 connections coming off of the icm , and the 2 connections plugs going to the coil.
gem1138
Report this Post11-20-2013 05:04 PM Click Here to See the Profile for gem1138Send a Private Message to gem1138Edit/Delete MessageReply w/QuoteDirect Link to This Post
So you typed this post while driving 120 mph?
Sorry Chris. I couldn't resist.
Chris-Winfield
Report this Post11-21-2013 01:04 PM Click Here to See the Profile for Chris-WinfieldSend a Private Message to Chris-WinfieldEdit/Delete MessageReply w/QuoteDirect Link to This Post
ignition coil , i think involves speedo signal correct? for all I know sitting for 1-2 day might get it back working but I think I need to do a thorough cleaning probably.
84fiero123
Total ratings: 325
Report this Post11-21-2013 02:31 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
They sell a spray can of electrical connection cleaner, I bought some for our home stereo, probably older than most of the members here on the forum, the stereo not the spray can. you could try than and wait for the excess to dissipate then plug it back in and see what happens. I hate electrical problems, I would rather pound my balls flat with a sledge hammer than hunt down an electrical problem.
good luck.
Steve
Chris-Winfield
Report this Post11-21-2013 03:33 PM Click Here to See the Profile for Chris-WinfieldSend a Private Message to Chris-WinfieldEdit/Delete MessageReply w/QuoteDirect Link to This Post
agree on the electrical issues , but not your alternative :P
I'll try it out when I get a chance and see if fixes my speedo issue , I am just hoping I didn't somehow damage the speedo
Total ratings: 236
Report this Post11-21-2013 04:59 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ignition has nothing to do with the speedometer.
A voltage spike on the speedometer can peg it. Due to the nature of the mechanism it will NOT come back around to zero (well... it's trying to come back around the bottom, so all it does is push on the peg).
Get the car up to about 60 and the speedo *should* fix itself.
Chris-Winfield
Report this Post11-21-2013 08:42 PM Click Here to See the Profile for Chris-WinfieldSend a Private Message to Chris-WinfieldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright I'll that and see hopefully it works.
I was just going through the diagrams when I posted that and thought I saw something that could indicate it so figured I'd ask , some of these diagrams confuse me.
[This message has been edited by Chris-Winfield (edited 11-21-2013).]
Goliath
Report this Post11-21-2013 11:57 PM Click Here to See the Profile for GoliathSend a Private Message to GoliathEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had the same problem with the speedo once stuck at 120. I figured i could judge speed on the highway by tach.
But once i got up to around 50 the needle popped up and it started working again.
Chris-Winfield
Report this Post11-22-2013 08:39 AM Click Here to See the Profile for Chris-WinfieldSend a Private Message to Chris-WinfieldEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice , well ill probably drive it today see if I can get it fixed , haven't registered the car at all so kind of wasted money it sort of looks like , but its a good thing I live out of town with alot of backroads.
Chris-Winfield
Report this Post12-04-2013 03:54 PM Click Here to See the Profile for Chris-WinfieldSend a Private Message to Chris-WinfieldEdit/Delete MessageReply w/QuoteDirect Link to This Post
fixed once I got to around 40
