  Bench Bleeding Master Cylinder
Bench Bleeding Master Cylinder by animal
Started on: 11-18-2013 06:08 PM
Replies: 3 (135 views)
Last post by: BlackEmrald on 11-18-2013 07:45 PM
animal
Report this Post11-18-2013 06:08 PM Click Here to See the Profile for animalSend a Private Message to animalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've run into another situation I'm not familiar with - if you remove the master cylinder is it necessary to bench bleed it again to reinstall it??
pontiacfierokid1985
Report this Post11-18-2013 06:41 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
As long as the master cyl didt get empty u should be ok with putting it back on and bleeding all four wheels
animal
Report this Post11-18-2013 06:51 PM Click Here to See the Profile for animalSend a Private Message to animalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure its empty.
BlackEmrald
Report this Post11-18-2013 07:45 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by animal:
I'm sure its empty.
Then yes, you will have to bench bleed. Is it a new/reman unit, or an old original part?
Bench bleeding an old one cause ruin the internal seals when the piston is retracted past ita normal operating travel and the corrosion rips the seals. So be careful
