  Is the stock computer programmable? Anyone used a chip? Not sure if this works
Is the stock computer programmable? Anyone used a chip? Not sure if this works by FieroGT-987
Started on: 11-18-2013 05:08 PM
Replies: 2 (213 views)
Last post by: FieroGT-987 on 11-18-2013 06:11 PM
FieroGT-987
Report this Post11-18-2013 05:08 PM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Would either of those work on a 87 fiero gt? Thanks a lot
dobey
Total ratings: 371
Report this Post11-18-2013 05:25 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the chip can be replaced, and the chips are programmable, but you can't flash the ECM like on new OBD-II cars. You have to remove the chip, stick it in a programmer, and then program it in the same classic manner of programming EEPROMS.
Though 99% of the aftermarket "performance" chips for the Fiero are a waste of money. If your car is stock, you don't need to change the chip from stock, unless the stock one is bad. Then you should replace it with a good stock chip/program.
FieroGT-987
Report this Post11-18-2013 06:11 PM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
So it wont make a difference if i put a programmed chip in it? I only have egr block off and performance exhaust with out cats. Little quicker than stock right now. Anyone have any ideas for little power gains? Thanks
