  Auto Transmission Light
Auto Transmission Light by avlonfrg
Started on: 11-14-2013 10:10 AM
Replies: 3 (113 views)
Last post by: Grantman on 11-14-2013 01:39 PM
avlonfrg
Report this Post11-14-2013 10:10 AM Click Here to See the Profile for avlonfrgSend a Private Message to avlonfrgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Due to my age and eyesight restrictions, I very rarely drive my 87GT at night. Isn't there a light under the signage for the various gears? I ask simply because I don't want to have to take the assembly apart to replace a lamp if I don't need to.
John W
Baltimore
jaskispyder
Total ratings: 205
Report this Post11-14-2013 10:48 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, there is supposed to be one.
Just take the shifter plate off (or lift it enough) and twist off the light socket and replace the bulb.
There are also bulbs for each ashtray, if you want to get those while you are there.
[This message has been edited by jaskispyder (edited 11-14-2013).]
Total ratings: 200
Report this Post11-14-2013 10:59 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
John W
Baltimore
Just like Jaskispider said. You might also want to consider replacing them with LED bulbs. They'll last much longer.
Grantman
Report this Post11-14-2013 01:39 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also don't forget to slide the gearshift lever through the plastic slide thing under the cover where the bulb is located. If it isn't located in the right place you can't move the lever to 2 or 1 (if you had a reason to do so that is).
