  can I buy a new fuel pump assembly?
can I buy a new fuel pump assembly? by fisherlr777
Started on: 11-14-2013 12:24 AM
Replies: 8 (284 views)
Last post by: Lou6t4gto on 11-15-2013 11:49 PM
fisherlr777
Report this Post11-14-2013 12:24 AM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
I Have A Donor FierO Gas Tank but The Fuel Pump Assembly And Level Sender Have All Gotten Rusty.
rcm
Report this Post11-14-2013 08:54 AM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a new Delphi assembly on ebay for 300 bucks.
avlonfrg
Report this Post11-14-2013 10:02 AM Click Here to See the Profile for avlonfrgSend a Private Message to avlonfrgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Apparently I haven't kept up to date on such things, but I checked eBay and there are a number of fuel pump repair kits available for under $50, including one made by Delco. It comes with a new pump and other parts which will allow you to rebuild the assembly.
John W
Baltimore
Total ratings: 461
Report this Post11-14-2013 01:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be careful.
Should I be ticked off that the fuel pump I received is not what I ordered?
fisherlr777
Report this Post11-14-2013 03:11 PM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its for 88's, i saw that listing already.
fisherlr777
Report this Post11-14-2013 03:13 PM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
fisherlr777
Member since Sep 2013
John W
Baltimore
The fuel pump is available through most parts stores, but i have yet to find an assembly with the floater and fuel level sender.
fisherlr777
Report this Post11-14-2013 03:24 PM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
fisherlr777
FOUND!
http://www.fierostore.com/P...px?s=60912&d=240&p=3 Its for 85-88s and apparently the 4-cylinders use different pigtails for the pump.
Neils88
Total ratings: 56
Report this Post11-14-2013 09:23 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fisherlr777:
FOUND!
That's the one I bought for my '88 2.5L. Worked perfectly...no issues with electrical. Plugged right in. The vent line points down, so you either need a slightly longer hose, or gently bend it straight.
Lou6t4gto
Report this Post11-15-2013 11:49 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
You ARE aware that the 4 cyl and 6 cyl fuel pumps don't interchange, right ?
