  86 gt tach in a 85 doesnt work after install but original 85 works
86 gt tach in a 85 doesnt work after install but original 85 works by pontiacfierokid1985
Started on: 11-04-2013 02:26 PM
Replies: 6 (130 views)
Last post by: pontiacfierokid1985 on 11-04-2013 09:15 PM
pontiacfierokid1985
Report this Post11-04-2013 02:26 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok im confused i pulled the guages out of a 86 gt at a local bone yard just the fuel/temp guage and the tach already have the 120 speedo. The fuel and temp guage work fine but the tach just wants to stay up by x1000 rpm reading what did i do wrong ???? Or am i missing something else to make it work
Arns85GT
Total ratings: 202
Report this Post11-04-2013 04:09 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is likely dead. They are a plug and play, if they are working
Arn
Arns85GT
Total ratings: 202
Report this Post11-04-2013 04:12 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Arns85GT
Member since Jul 2003
If you wanted it due to the backlit feature, I overcame that difficulty and kept the 85 tach by cutting slots along the top edge of the casing to allow the light from inside the dash unit to shine onto the face of the tach. This has worked very well. I use it with an 86 speedo and an 86 fuel/heat unit
Arn
Report this Post11-04-2013 04:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a 5-spd '88 Formula over the summer that came without an instrument cluster. I figured it wasn't really a problem as I had three or four extra instument clusters here originally from V6 Fieros.
Would you believe that not one of the tachs work properly. All the rest of the gauges are fine, but the tachs all either read too high, too low, or nothing at all.
pontiacfierokid1985
Report this Post11-04-2013 05:41 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
That sucks cause i really want the 86-88 tach looks so much better then the 85
Arns85GT
Total ratings: 202
Report this Post11-04-2013 06:40 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say to check the tach filter except the old one is working.
Arn
pontiacfierokid1985
Report this Post11-04-2013 09:15 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea i found another guage cluster another local yard has one he has its a se 86 that has the 85 speedo but it has the 2.8 in it he has it doesnt have the oil pressure guage under the tach so i know thats the right one im gonna pick it up on veterans day next week
