| | | quote | Originally posted by PatrickTRoof:
My odometer and trip counter were not working, and today the trip counter magically started working again, but not the odometer. It's worth noting that I had removed the cruise control components from under the hood when I did my engine replacement, and did not put them back (I have no idea where they are now... ) I read on another thread that the cruise has something to do with the odometer working or not. Any clues? |
Not in the Fiero...
In other cars of similar age (or older), the speedometer (and odometer) are driven by a cable which may often first connect to the cruise control. In the Fiero however, the speedometer and odometer are both driven by voltage input. Both the odometer and speedometer have separated motors which drive the gauges (and the wheel roll). If the connection is bad, the speedometer (or odometer, or both) will stop working. My guess is that the connection is bad, which would explain why one of them just randomly started working, but the other still does not.
Try taking out the gauges and seeing if the motors move freely... the motors look like this:
(K for kilometers, and M for miles)
Although I'm 100% American, I thought it would be cool to get the metric gauges, so I swapped in Canadian gauges into my car and kept the MILES motor for the odometer, but swapped out the KPH motor for the speedometer.
EDIT: Accidentally posted this in the wrong thread... there are two people with gauge problems, but the info should be useful either way. Sorry!
[This message has been edited by 82-T/A [At Work] (edited 11-04-2013).]
