  lower the rad?
lower the rad? by northstar
Started on: 10-31-2013 10:14 AM
Replies: 6 (418 views)
Last post by: northstar on 10-31-2013 09:05 PM
northstar
Report this Post10-31-2013 10:14 AM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can the rad be lowered at all in the front?
Arns85GT
Total ratings: 202
Report this Post10-31-2013 10:46 AM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
the rad sits on a rubber gasket on the cross member. It would take experimenting unless someone has found the way. I don't know why though, when a correct size 3 core is about $300
Arn
northstar
Report this Post10-31-2013 10:57 AM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks arn..we are taking the original rad out now
tesmith66
Total ratings: 135
Report this Post10-31-2013 11:25 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you can. I used a 68 Nova 3 core in my V8 swap by setting the lower mount down 2" and back enough maintain the same angle the stock rad sits at. I welded up some offset spacers to do this. I widened the stock upper mount slightly and opened up the opening for the cap a bit. The rest was plug and play.
Sorry, no pics. I went back to the stock V6 rad when I changed over to the DOHC motor.
1986 SE Aero coupe.
Total ratings: 200
Report this Post10-31-2013 06:45 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
It would take a little modifying, but it certainly could.
Here is a picture of what the radiator support looks like:
It's attached by four bolts... so technically you could just install spacers and I guess you could feasilbly install a taller radiator.
Report this Post10-31-2013 07:32 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made new radiator brackets to fit a 26x19 in place of the stock 24x16, so yes it can be done.
northstar
Report this Post10-31-2013 09:05 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I GOT LUCKY ON THIS ONE..ALL WE NEEDED to do was to remove the top rad hold down and move the fan dow the rad a little, that gave me the rite amount of clearance thanks all
