  7730 ecm swap questions.
7730 ecm swap questions. by 86fiero3.4
Started on: 10-30-2013 06:57 PM
Replies: 11 (601 views)
Last post by: 86fiero3.4 on 10-31-2013 04:49 PM
86fiero3.4
Report this Post10-30-2013 06:57 PM Click Here to See the Profile for 86fiero3.4Send a Private Message to 86fiero3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
What all is needed?
Does Anyone make harness' or am i stuck repining?
Thanks guys and gals.
JCircs
Report this Post10-30-2013 07:05 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just installed mine with a real nice harness made by Phonedawgz.
86fiero3.4
Report this Post10-30-2013 07:25 PM Click Here to See the Profile for 86fiero3.4Send a Private Message to 86fiero3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ill have to pm him.
Total ratings: 290
Report this Post10-30-2013 08:15 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hear he is a jerk
Report this Post10-30-2013 08:29 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The ratings bar does not agree with that.
86fiero3.4
Report this Post10-31-2013 06:46 AM Click Here to See the Profile for 86fiero3.4Send a Private Message to 86fiero3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dawgs, amy price input?
I want to go DIS, add knock and crank sensors, delete cold start injector, and evap sp i can get rid of the plugs just chilling out by my intake
Report this Post10-31-2013 10:17 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think fierocarparts is having some issues with phonedawgz at the moment, but I don't know if anyone else is. He's always done good work and provided good information.
If you change over to the 7730, you will need to swap out to the digital EGR system. Georgia Fieros sells an EGR adapter kit for conversion to the digital EGR. http://www.gafiero.org/shop.shtml
JCircs, did you change to a digital EGR? If you did, where did you get your adapter kit?
[This message has been edited by fierofool (edited 10-31-2013).]
86fiero3.4
Report this Post10-31-2013 10:57 AM Click Here to See the Profile for 86fiero3.4Send a Private Message to 86fiero3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im not using EGR. My 3.4 is tuned now with it dissabled and i have no issues. I want to 7730 swap so i am ready for turbo and can actually tune and know everything is good instead of hoping for the best.
JCircs
Report this Post10-31-2013 11:41 AM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I deleted my EGR when I did my turbo.
86fiero3.4
Report this Post10-31-2013 12:39 PM Click Here to See the Profile for 86fiero3.4Send a Private Message to 86fiero3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
So i need the ecm, oil pump drive, coil packs, crank sensor (from a 3400?) and knock sensor.
Than i just have the wiring to worry about?
Total ratings: 290
Report this Post10-31-2013 02:57 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I take it that you want to do a 7730 & DIS.
$300 + 20 shipping
$45 if I supply the donor Fiero harness
$40 if you want to add digital cruise wiring
$70 for a 7730 with a V6 MEM/CAL with a PROM socket (programming not included)
86fiero3.4
Report this Post10-31-2013 04:49 PM Click Here to See the Profile for 86fiero3.4Send a Private Message to 86fiero3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. Ill be contacting you soon.
