  WinALDL causes AVG to sandbox file
WinALDL causes AVG to sandbox file by deceler8
Started on: 10-29-2013 06:54 PM
Replies: 2 (170 views)
Last post by: 82-T/A [At Work] on 10-31-2013 06:41 PM
deceler8
Report this Post10-29-2013 06:54 PM Click Here to See the Profile for deceler8Send a Private Message to deceler8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone else run across this ?
I have the serial ALDL cable and the CD that came with it, and when I try to install WinALDL AVG won't allow me to install.
Is there a workaround for this that doesn't require me to uninstall AVG ? It's a Dell Latitude laptop with Windows XP (Circa 2007).
Damn spiders.
Total ratings: 290
Report this Post10-30-2013 05:54 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run TunerPro RT instead. The free version of runs 100% after a 10 second nag screen. TP is easier to set up. I WinALDL worked with your cable then TP will work also. TP gives you much better graphics than WinALDL.
There simply isn't anything WinALDL does better than TP.
http://tunerpro.net
Total ratings: 200
Report this Post10-31-2013 06:41 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Damn spiders.
Hi! You can right-click on the AVG icon in the taskbar, and select "Temporarily Disable AVG"
This will give you enough time to be able to install Win ALDL.
