  Firebird Radio w/ Performance Sound, modded AUX port, and CD Changer
Firebird Radio w/ Performance Sound, modded AUX port, and CD Changer by rbell2915
Started on: 10-26-2013 11:19 PM
Replies: 13 (913 views)
Last post by: Fiero Tom on 10-30-2013 12:05 AM
rbell2915
Report this Post10-26-2013 11:19 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Once I finish collecting all the parts needed to install the performance sound system, I began wondering about overhauling the sound system in my car a little bit to make it more functional.
What I want is this:
with an auxiliary port installed in it, and hooked up to the performance sound and wired up to a CD-changer (in the trunk).
Now, I was curious as to whether or not this was possible to do and what is needed to do this. What CD changer to use, what harness to use, where to buy all of this, everything.
Winter is coming soon, so I'll have plenty of time to do this if it's a major and costly project.
PS: If anyone happens to know the mounting depth of the speakers in the dash and on the B-Pillars, that'd be greatly appreciated too!
Thanks
-1986 Pontiac Fiero GT
*October 2, 2012
[This message has been edited by rbell2915 (edited 10-27-2013).]
fierosound
Total ratings: 286
Report this Post10-27-2013 03:39 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
CD Changers are obsolete.
Once you have a way to connect an MP3 player of some type that's all you need.
See here: https://www.fiero.nl/forum/Forum3/HTML/000031.html
Calgary time/temp
[This message has been edited by fierosound (edited 10-27-2013).]
Phirewire
Report this Post10-27-2013 05:50 AM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
MarkS
Report this Post10-27-2013 09:18 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have my eye on this set up:
http://replacementradios.co...h=23&products_id=227
For MP3 or satellite input, one more adapter required:
http://replacementradios.co..._351&products_id=972
BR's,
Mark
86 SE V6 4 speed
86 SE V6 Auto
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
rbell2915
Report this Post10-27-2013 07:48 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I decided to go against the CD changer. I just thought it'd be neat to have, but it'd be adding extra work and money.
And why did you choose to go with the Monsoon unit? What makes it more special?
rbell2915
Report this Post10-27-2013 07:50 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
rbell2915
Member since Mar 2013
Originally posted by Phirewire:
http://eurosportvr.com/misc/ipod%20input/index.htm
Also.
Thanks for the help!
rbell2915
Report this Post10-27-2013 07:52 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
rbell2915
BR's,
Mark
Thank you for the links, but I'm a little confused on what exactly the second link is for? Why would I need that? Thanks again!
MarkS
Report this Post10-27-2013 08:36 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
The second link is used to connect an Ipod or satellite receiver to the radio in the first link. If you not plan to connect anything to the radio in the first link then you do not need it.
BR's,
Mark
rbell2915
Report this Post10-27-2013 08:40 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
All right, thanks. I was a little confused on what it was talking about lol
TbirdMarc
Report this Post10-28-2013 06:02 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
This link will work for your radio. I just did my radio with EQ, same as yours using these instructions. The CD connector is in a different position but everything else is the same.
http://grassrootsmotorsport...o-radio/30292/page1/
[This message has been edited by TbirdMarc (edited 10-28-2013).]
Fiero Tom
Report this Post10-29-2013 07:51 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can always buy a modded radio from me ........... Delco AM/FM/CD EQ Radios with AUX in Added https://www.fiero.nl/forum/Forum4/HTML/067351.html
I'm offering these at $125 for the radio, $145 plug-n-play with the wiring and antenna adapters.
[This message has been edited by Fiero Tom (edited 10-29-2013).]
Fiero Tom
Report this Post10-29-2013 08:05 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Tom
Member since Jun 2002
BR's,
Mark
You have PM
rbell2915
Report this Post10-29-2013 08:57 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
I remember that thread and what do you mean "plug-n-play with the wiring and antenna adapters?" Sorry, I'm still learning everything.
And I'm assuming you might be able to do Monsoon units? Or are they different internally? Thanks!
Fiero Tom
Report this Post10-30-2013 12:05 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the adapters you simple take out your existing radio out, plug in the adapters to the existing wiring and antenna and bolt in your new radio.
I haven't tried a Monsoon radio so I can't say if they are different internally but I know the standard radios vary and I have been successful only with a few model numbers.
