  instrument cluster wiring diagram 86 se needed
instrument cluster wiring diagram 86 se needed by northstar
Started on: 10-24-2013 10:14 PM
Replies: 4 (786 views)
Last post by: northstar on 10-27-2013 05:08 PM
northstar
Report this Post10-24-2013 10:14 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
anyone have a wiring diagram for the instrument cluster of an 86 se with an automatic 2.8 im having issues with my charging and need to see where the diode is located that is built into the wire that leads to the batt. light in the instrument cluster .i want to find the diode ,see what type and what kind it is and go to radio shack and replace it,, if this is even possible.. thank you c
[This message has been edited by northstar (edited 10-24-2013).]
chetw77cruiser
Report this Post10-24-2013 10:44 PM Click Here to See the Profile for chetw77cruiserSend a Private Message to chetw77cruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
A 1N4002 diode would work nicely
northstar
Report this Post10-24-2013 11:01 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you for the info ..i hope this gets me on the road c
Bloozberry
Total ratings: 311
Report this Post10-25-2013 08:04 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Although not particularly helpful, the FSM says that the diode is: "In the main harness, below rear bulkhead grommet."
northstar
Report this Post10-27-2013 05:08 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
car is charging now,, wiggle method worked this time,, yep wiggle method,,,thanks everyone
