  Replacing front bushing
Replacing front bushing by 4thfiero
Started on: 10-23-2013 05:38 PM
Replies: 5 (180 views)
Last post by: theogre on 10-24-2013 03:37 AM
4thfiero
Report this Post10-23-2013 05:38 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
How hard is it to remove and replace front suspension bushing, mine are poly and they squeek like crazy...probably gonna get rubber ones. Special tools needed? Thanks guys.
gtoformula
Report this Post10-23-2013 08:40 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Poly bushings need to be assembled with lube to prevent squeaking. You might want to try taking the control arms off, luging them up and reassemble. That will be easier than replacing the bushings. The polys will come out easy, but pressing in the new rubber ones requires care to not bent the arms.
katatak
Total ratings: 82
Report this Post10-23-2013 09:28 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use extreme caution with the coil spring!
MulletproofMonk
Total ratings: 78
Report this Post10-23-2013 09:53 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is my Poly Suspension Upgrade (all pics) thread... Just reverse the steps...
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
4thfiero
Report this Post10-24-2013 12:36 AM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys! Also...use extreme caution with the springs, I was thinking about that...whats a safe method to replace front springs??
Total ratings: 568
Report this Post10-24-2013 03:37 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need tool to press rubber bushings.
See my Cave, Bushings
Spring... Fiero front springs are easy. just watch it can't pinch/hit you.
Front...
do top, install UCA, then do bottom.
ignore tie rod
[This message has been edited by theogre (edited 10-24-2013).]
