  Opening on side of block, what goes there?
Opening on side of block, what goes there? by gtemplet
Started on: 10-23-2013 04:14 PM
Replies: 10 (264 views)
Last post by: fierofool on 10-23-2013 11:57 PM
gtemplet
Report this Post10-23-2013 04:14 PM Click Here to See the Profile for gtempletSend a Private Message to gtempletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finishing up my 2.8 V6 rebuild and I don't have enough parts (plenty of extra bolts though) there is a machined surface with 2 threaded holes and a larger opening (about 1in) in the middle. The opening is on the oil filter side a/c compressor corner. It appears it would be a coolant passage. What connects to this? I can't remember removing anything from this location. I searched a lot of pictures but anything I found the compressor was in the way. Thanks for looking, any help is appreciated.
[This message has been edited by gtemplet (edited 10-23-2013).]
Total ratings: 154
Report this Post10-23-2013 04:20 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the engine torque shock bolted in place? It's just to the drivers side of the oil filter.
gtemplet
Report this Post10-23-2013 04:34 PM Click Here to See the Profile for gtempletSend a Private Message to gtempletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I have the torque shock, the opening is above that. I'm at work or I'd take a picture.
Pyrthian
Total ratings: 342
Report this Post10-23-2013 04:36 PM Click Here to See the Profile for PyrthianSend a Private Message to PyrthianEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was guessing oil pressure sending unit, until I saw 1" opening......
gtemplet
Report this Post10-23-2013 04:49 PM Click Here to See the Profile for gtempletSend a Private Message to gtempletEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you were looking at the side of the block it would be along the edge of the timing cover. If the coolant hose that runs thru the compressor bracket opening wer installed it would hide the machine surface/hole.
Pyrthian
Total ratings: 342
Report this Post10-23-2013 05:07 PM Click Here to See the Profile for PyrthianSend a Private Message to PyrthianEdit/Delete MessageReply w/QuoteDirect Link to This Post
yikes - a mechanical fuel pump??
trotterlg
Report this Post10-23-2013 06:38 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure could be a fuel pump mount, that would be the right place. Larry
Blacktree
Total ratings: 350
Report this Post10-23-2013 06:50 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's where the fuel pump would mount on a carbureted engine. The hole in the middle shouldn't go all the way through, because it isn't drilled out on fuel injected engines.
Bloozberry
Total ratings: 311
Report this Post10-23-2013 07:22 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
gtemplet
Report this Post10-23-2013 07:47 PM Click Here to See the Profile for gtempletSend a Private Message to gtempletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you gentlemen. I guess I should have painted over it then. Getting old sucks, I would have sworn I didn't take anything off from there but there was a nice machined surface there so something had to go there. I looked all over the garage and basement (wife isn't to happy about parts in basement lol) for something that would fit there. Thanks again guys.
Total ratings: 154
Report this Post10-23-2013 11:57 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man, was I out of the ball park with the torque shock. The picture wouldn't load for me until just now and I couldn't see that big hole. That is one nice looking engine. Very clean.
