  grinding noise when going into reverse
grinding noise when going into reverse by Jecklen16
Started on: 10-19-2013 05:12 PM
Replies: 4 (214 views)
Last post by: Blacktree on 10-19-2013 06:20 PM
Jecklen16
Report this Post10-19-2013 05:12 PM Click Here to See the Profile for Jecklen16Send a Private Message to Jecklen16Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I have an 85 fiero gt and when shifting through my four gears its smooth and perfect. When I go into reverse however there is a high pitched grinding noise before it pops in. Any ideas?
Check clutch fluid level its good, this is when car is warm or cold doesn't Matter.
Shill
Report this Post10-19-2013 05:39 PM Click Here to See the Profile for ShillSend a Private Message to ShillEdit/Delete MessageReply w/QuoteDirect Link to This Post
leave the clutch in, put it in 2nd before attempting to go into reverse. This will help stop everything from moving. I assume a 4spd?
Jecklen16
Report this Post10-19-2013 05:42 PM Click Here to See the Profile for Jecklen16Send a Private Message to Jecklen16Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ya 4 speed, so I don't release the clutch in second right?
Shill
Report this Post10-19-2013 05:49 PM Click Here to See the Profile for ShillSend a Private Message to ShillEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, do this all while the clutch is held in. Does not fix the issue at hand mind you, but eliminates all the symptoms, and does not cause any further excess wear. Does not make you look like an idiot in the parking lot trying to back up your car. I've been using this trick for years. Only way I know of ultimately fixing it is to replace the transmission. In my eyes it is not needed. Nothing bad will come of putting it in second every time before reverse.
Blacktree
Total ratings: 350
Report this Post10-19-2013 06:20 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also, make sure the car is completely stopped before shifting into Reverse. The Reverse gear doesn't have a synchronizer.
