  Accelleration issue
Accelleration issue by 4thfiero
Started on: 10-17-2013 05:20 PM
Replies: 5 (142 views)
Last post by: Bloozberry on 10-18-2013 07:49 AM
4thfiero
Report this Post10-17-2013 05:20 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
2.8 v6 88 Fiero
Having a power issue with it, feels very sluggish. No check engine light. took it to my mechanic, electronics are all good. Fuel and spark are good. But did a smoke test and checked for vacuum leaks, found 2, one is that thick hose under the upper plenum, the 2nd is where the lower plenum mates with the block. Tech thinks that bcc of those intake leaks. The engine isnt getting enough air to all the cylinders.
Could that be my power issue?
Report this Post10-17-2013 05:57 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
don't think so. What's your idle speed?
f85gtron
Report this Post10-17-2013 06:02 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
probably getting too much air. is your idle high?
4thfiero
Report this Post10-17-2013 06:21 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Idle is fine, either right at 1k or JUST under, steady idle.
4thfiero
Report this Post10-17-2013 09:13 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
4thfiero
Member since Oct 2012
When its warmed up that is...idle seems fine, only other symptoms are a slight hesitation on accel when the engine is cold. Like its about to stall, and the engine sounds a bit louder than normal
Bloozberry
Total ratings: 311
Report this Post10-18-2013 07:49 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
It could be your cat or your muffler are choked off with internal failure of the baffles.
