  Clutch fork problems
Clutch fork problems by Imnuts
Started on: 10-15-2013 11:20 AM
Replies: 9 (246 views)
Last post by: Imnuts on 02-28-2014 08:47 PM
Imnuts
Report this Post10-15-2013 11:20 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My clutch fork has slipped off my throw-out bearing two times on my 88 GT. This destroys the fork and pressure plate each times it happens. I don't know how it can do this unless somehow its over extending. The first time I had bought the car and drove about 800 miles. The second was after a complete rebuild with all the components new including the clutch fork lasted 1400 miles.
Does anyone know what causing this?
Report this Post10-15-2013 11:36 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum! What do you know about your slave cylinder? There are different cylinders and push-rods that could be the problem.
aaronkoch
Report this Post10-15-2013 12:05 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you trying to use an isuzu throwout bearing with a muncie or getrag fork?
Throwout bearings are matched to transmission, as are the forks, and if the PO swapped trannies while trying to keep the old TO bearing, I could see this happening.
Imnuts
Report this Post10-15-2013 02:34 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The slave cylinder I sure was replace by the previous owner. I know it’s the correct length push rod because when I was a newbie at bleeding the clutch I looked into that. The Getrag tranny was original to the car as is the 2.8. I replace the flywheel and installed a new clutch kit the later was an AC Delco (made by Sachs) both ordered from Rock Auto. I also installed a new clutch fork (ordered from Sachs) since it was damaged from trying to chew through the pressure plate’s spring fingers. Somehow the clutch fork is getting driven past the throw-out bearing. I guess I try to find out if I have the correct slave cylinder. Is there a particular clutch kit that you would recommend?
Thanks for the quick reply.
aaronkoch
Report this Post10-15-2013 04:05 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use rockauto or the fiero store, but I don't see any mention of the throwout bearing.. where did you get that from (or did you replace it?) and is it the correct one for your transmission?
trotterlg
Report this Post10-15-2013 04:08 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Post a picture of the TO bearing you are using. Larry
Imnuts
Report this Post10-15-2013 08:12 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The clutch kit pictured is the one I bought from Rockauto and it came with the bearing qnd a better looking picture of the bearing.
trotterlg
Report this Post10-16-2013 12:10 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
That looks like the proper TO bearing for sure. Larry
Imnuts
Report this Post10-16-2013 08:33 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess when I get around to removing the clutch I will check out the slave cylinder to make sure it's correct. But first I have to work on numerous home projects for my wife since I spent all last winter doing a engine/drivetrain rebuild and this summer going to car shows. Has anyone else had this clutch fork problem?
Max
Imnuts
Report this Post02-28-2014 08:47 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
It ended up being a bad clutch disk that fell apart after 1500 miles just felt the same as the fork slipping off.
Thanks for the replies anywho.
