  TSB 738101R implementaion
TSB 738101R implementaion by flimbob
Started on: 10-14-2013 08:18 AM
Replies: 2 (393 views)
Last post by: theogre on 10-15-2013 07:25 PM
flimbob
Report this Post10-14-2013 08:18 AM Click Here to See the Profile for flimbobSend a Private Message to flimbobEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone implement TSB 738101R? It can be located by Google search or found in Ogre's Cave under oil sender. Ogre recommends the shield should be disregarded for the 85-87 V6. Instead, update to the 88 sender and modify the sender location as per the TSB for the 88 V6. How does the elimination of the sender tube affect oil pressure readings?
masospaghetti
Report this Post10-15-2013 01:51 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
It shouldn't affect readings at all, there's no pressure drop in the tube. It does eliminate a common leak point and allow use of a more reliable sending unit.
Report this Post10-15-2013 07:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
TSB is 88822 or 88-8-22 depending on list you look for. Example Alldata list w/o dashes.
Correct.
