  egr tube?
egr tube? by NiotaFiero
Started on: 10-13-2013 06:44 PM
Replies: 7 (446 views)
Last post by: NiotaFiero on 10-15-2013 06:40 AM
NiotaFiero
Report this Post10-13-2013 06:44 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I pulled my egr tube to replace it and replace gaskets on it. There is oil in the tube, is this normal ? And the gasket on the end connecting to the plenum has a smaller hole in it than on the other end, is this the way it should be ? Thanks for any replies.
[This message has been edited by NiotaFiero (edited 10-13-2013).]
Report this Post10-13-2013 06:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by NiotaFiero:
And the gasket on the end connecting to the TB...
The EGR tube doesn't connect to the throttle body.
NiotaFiero
Report this Post10-13-2013 07:11 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I meant where it connects to the plenum.
NiotaFiero
Report this Post10-13-2013 07:46 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
NiotaFiero
Member since Nov 2007
Report this Post10-14-2013 02:46 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's probably working it's way there from the breather tube which is stuck in the rubber elbow just before the TB. Some oil is probably "normal", although the less the better.
I believe that's correct.
Rodney
Total ratings: 267
Report this Post10-14-2013 12:05 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. This stops a high idle run away condition if the EGR tube breaks off the flange.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
NiotaFiero
Report this Post10-14-2013 08:33 PM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, I appreciate the help that is available here.
NiotaFiero
Report this Post10-15-2013 06:40 AM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
