  Using F-body dual piston brakes on a Fiero
Using F-body dual piston brakes on a Fiero by djlamp14
Started on: 10-11-2013 09:23 PM
Replies: 10 (395 views)
Last post by: djlamp14 on 10-12-2013 11:52 PM
djlamp14
Report this Post10-11-2013 09:23 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a set that are on my regal. I'm in the process of demodding it for the fiero build. I haven't seen anything about you guys being able to use them. If I can use them I'll save them otherwise I'll sell them off too.
Thanks guys
jb1
Report this Post10-11-2013 09:48 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
it is what I am using with 13" c4 rotors.
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 10-11-2013).]
Ang84Indy
Report this Post10-12-2013 01:22 AM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year F-body?
djlamp14
Report this Post10-12-2013 02:00 AM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
like 2001ish
jb1
Report this Post10-12-2013 02:06 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
98 to 02 dual piston
87 GT
86GT 3800 n/a
My Build
djlamp14
Report this Post10-12-2013 04:06 AM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you guys using them on the front or rear? All fours? Just wondering. It might not even be an option for me since I would ideally like to have 15" welds on all fours
jb1
Report this Post10-12-2013 04:48 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
right now just on frint but workin in 13" setup in rear, you co ulc use them o n an 11" or 12" setup I wiuld guess but I have only seen them in 12 an 13"..
87 GT
86GT 3800 n/a
My Build
djlamp14
Report this Post10-12-2013 03:45 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info guys. I'll prolly save them then.
thesameguy
Report this Post10-12-2013 05:50 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
When researching calipers for doublec4's front C5 brackets, what I believe I learned is that 4th gen f-body, c5, and c6 calipers are all essentially interchangeable - the same dimensions. What changes is the piston sizes and pad carriers, and in some cases the structural design, but they'll all similar.
jb1
Report this Post10-12-2013 11:51 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
the abuntment bracket is shorter on the c5 setup, but the caliper itself is interchangeable. Brake overstock has the LS calipers and brackets powder coated red for $145pr and gm parts direct has the c5 abuntment brackets for like $35 each, My brackets were made by Purple reighn and made for the LS calipers.
The older CTS-V calipers that are 4 piston are interchangeable with the LS caliper but the " bracket" and caliper is all one piece but bolts in place of the LS calipers
87 GT
86GT 3800 n/a
My Build
djlamp14
Report this Post10-12-2013 11:52 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yup I know. I was just curious as to what is popular is this platform for brake swaps.
