  Getrag mounting bracket problem.
Getrag mounting bracket problem. by sspeedstreet
Started on: 10-10-2013 08:38 PM
Replies: 1 (108 views)
Last post by: Gall757 on 10-11-2013 09:55 AM
sspeedstreet
Total ratings: 53
Report this Post10-10-2013 08:38 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a question about Getrag mounting bosses maybe some-one can answer. I bought a set of CC Rider's 1" lowering transmission brackets for my 1988GT. The rear bracket did not line up with my trans. If the top and bottom were bolted through the third hole was off by one half a bolt diameter. The vender was good enough to send me another that he had checked on his mule and knew was correct. Same thing; it did not fit my trans. It was the first time CC had seen this. Did GM have different lay-outs for bolt patterns?
Thanks,
Neil
Report this Post10-11-2013 09:55 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The tolerances on the GM part are a lot tighter than the tolerances on CC's part.
Angle bends on metal that thick are tough to duplicate.
filing out the hole a bit won't hurt anything.
