  Exhaust fume smell
Exhaust fume smell by newfiejeff
Started on: 10-08-2013 12:10 PM
Replies: 4 (466 views)
Last post by: 2.5 on 10-09-2013 08:57 AM
newfiejeff
Report this Post10-08-2013 12:10 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2m4 5 speed
Just a stupid question, my car makes a fume exhaust smell, no smoke to be seen in as black smoke, but if you started the car in the garage for 10 seconds or so your clothes smell of exhaust. Would it be that I don't have an EGR valve and a catalytic converter?
Report this Post10-08-2013 02:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Th car will run rich for a while when it's cold. As soon as it goes into closed loop, the mixture should lean out, but may still be slightly rich. First suspect of anything failing would be the Oh2 sensor or the Coolant Temp Sensor. The one for the ECM-fuel injection, not the one for the gauge. It's located down at the bottom of the thermostat housing, positioned horizontally.
dobey
Total ratings: 371
Report this Post10-08-2013 03:00 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even at cold start it shouldn't smell rich, at least not without putting your face right next to the tail pipe. If the exhaust smells rich, then the cat is probably hollow already, if you've still got one on. Or you might have a leak before the cat, possibly at the EGR, or at the manifold.
If it smells more like gas than rich exhaust, you probably have a gas leak, likely at the fuel filter or at the line leading up to the throttle body (or fuel rails on a V6).
Report this Post10-08-2013 03:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by newfiejeff:
Would it be that I don't have... a catalytic converter?
Yes.
The duke is a "dirty" engine. IMO, without a cat it's going to stink.
Report this Post10-09-2013 08:57 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep without a cat exhaust stinks.
