  Interior light issue
Interior light issue by 4thfiero
Started on: 10-07-2013 11:56 PM
Replies: 3 (137 views)
Last post by: 4thfiero on 10-08-2013 08:14 PM
4thfiero
Report this Post10-07-2013 11:56 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found another gremlin tonight, driving home at night, interior lights work...except the speedo doesnt illuminate at all, (or its very dim) and the left turn signal indicator light is on solid...when i use the left signal light, it works just fine. Same with the right signal light. But when i use the right signal or not any of the signal at all it, the left stays solid. Any idea what this could be?? Bad ground?
Also when i was driving and hitting bumps, the left indicator light would go dim and bright to the bumps. :S
4thfiero
Report this Post10-08-2013 05:05 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know where the ground is for those issues?
Report this Post10-08-2013 07:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
maybe two different problems...
turn bulb on dash w/ parking light on only?
See my Cave, Sneak Path
worked on dash recently?
Bulb(s) and/or socket is iffy.
2 main plugs lost/bent copper trace on the plastic board because Copper looses bond to plastic. Carefully Make sure that copper are straight before you plug in the harness. No, I don't know what glue will work w/o damaging plastic etc now or down the road.
4thfiero
Report this Post10-08-2013 08:14 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks man, i'll check that out
