front end Squeek?? by 4thfiero
Started on : 10-07-2013 06:11 PM
Replies : 10 (164 views)
Last post by : theogre on 10-08-2013 01:29 AM
Oct 7th, 2013
4thfiero Member Posts: 835 From: Winnipeg, Manitoba, Canada Registered: Oct 2012
Hey everyone, a thanks to everyone who has helped me finish with these annoying gremlins after my rebuild. I got one more I need help with... Had my front balljoints and inner tie rods replaced, Also front wheel bearings with dickmans bearings. Question is: When i go over speed bumps or my ride gets bumpy, my front end suspension squeeks...What could that be? springs? the polyurethane bushings??
06:11 PM
Does noone know? The mechanic checked my bushings and they are fine, like no play...but maybe something needs to be wd-40'd?
08:20 PM
theogre Member Posts: 32520 From: USA Registered: Mar 99
quote Originally posted by 4thfiero: The mechanic checked my bushings and they are fine, like no play
get another shop...
Polly using on control arms are famous for noise problem. Especially when installed w/o enough lube or wrong lube.
------------------Dr. Ian Malcolm: Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should. (Jurassic Park)The Ogre's Fiero Cave (It's also at the top and bottom of every forum page...)
08:33 PM
Interesting, so poly bushings on control arms are not preferred?? Rubber much better?
09:26 PM
Patrick Member Posts: 39250 From: Vancouver, British Columbia, Canada Registered: Apr 99
quote Originally posted by 4thfiero: Interesting, so poly bushings on control arms are not preferred?? Rubber much better?
Time for you to read some archived threads.
I don't know how many times I've read of guys going back to rubber after installing poly control arm bushings.
09:29 PM
That's lame...the frame i got, came with poly bushings on the arms already. Can i lub the bushings with wd-40 so they stop squeaking temp? does that work?
09:43 PM
Gall757 Member Posts: 10938 From: Holland, MI Registered: Jun 2010
09:49 PM
katatak Member Posts: 7136 From: Omaha, NE USA Registered: Apr 2008
Needs to come apart and use proper lube or they will continue to squeak! Even when Lubed and assembled properly, squeaking can occur.
09:52 PM
Crap..k replace bushings...thanks guys! really appreciate it
09:59 PM
Macarchie Member Posts: 145 From: Fredericksburg, VA Registered: Sep 2012
When I rotate the tires and check the brakes, I spray some silicone spray lubricant on the bushings (every end of every bushing) and a grease gun squirt into each grease fitting. I have had no problems with squeaks since I got her. It is a simple and cheap solution and I like simple and cheap
HTH, Jimmy
------------------ 1987 coupe; Blue; 2.5L; 5spd
10:05 PM
Oct 8th, 2013
not really and yes for most users
search here and See my Cave, Suspension section.
01:29 AM
