  Isolation relay vs. Actuation relay - Headlight Debate
Isolation relay vs. Actuation relay - Headlight Debate by RyanNierman
Started on: 10-04-2013 09:46 AM
Replies: 4 (1325 views)
Last post by: fierofool on 12-07-2013 11:19 PM
RyanNierman
Report this Post10-04-2013 09:46 AM Click Here to See the Profile for RyanNiermanSend a Private Message to RyanNiermanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
I have a member here that sold me a relay part number 10031018 (identical relay is a 10027587 but not part of this debate). I asked for an isolation relay p/n 10022620. He is saying they are the same. I think he sent me an Actuator relay (mounted on the headlight buckets) from all the research I've done. This is for the 84-86 headlight systems.
Can we shed some light on this to help resolve?
Thank you!
[This message has been edited by RyanNierman (edited 10-04-2013).]
newfiejeff
Report this Post12-07-2013 03:02 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
NetCam
Report this Post12-07-2013 03:10 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
The isolation relay and the headlight relay are definitely not the same, looks like you have the one that goes on the motor, not the isolation relay.
mrfiero
Total ratings: 150
Report this Post12-07-2013 10:46 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RyanNierman:
Hello,
Thank you!
Like NetCam said, the two are not interchangeable. If you are replacing the isolation relay then you need part #10022620.....the other one will not work in that application.
Report this Post12-07-2013 11:19 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Either will plug into the other's harness, but the internal circuitry is different.
