  Failed State Inspection, Parking Brake dash light issue
Failed State Inspection, Parking Brake dash light issue by hdryder
Started on: 10-01-2013 01:00 PM
Replies: 15 (844 views)
Last post by: jimbolaya on 10-03-2013 12:26 PM
hdryder
Report this Post10-01-2013 01:00 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just got word, that my '87 GT 5-speed daily driver, failed the state inspection.
The Parking Brake dash light does not come on during initial key turn on, and also will not come on when the Parking Brake is pulled on.
(EDIT): I swapped the working CHECK ENG SOON bulb into the BRAKE bulb location, but could still not get the BRAKE light to come on when pulling up the E. Brake lever.
Has anyone else had this issue problem that had a complicated repair for a fix?
Thanks for the help.
[This message has been edited by hdryder (edited 10-02-2013).]
dobey
Total ratings: 371
Report this Post10-01-2013 02:18 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the bulb to me.
The typical failure is that the brake light stays on, even when the brake is not engaged, because the switch at the bottom of the handle is out of alignment, or bad.
hercimer01
Report this Post10-01-2013 02:43 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Could the lever be unplugged?
88 Coupe under construction
Report this Post10-01-2013 03:15 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"The Parking Brake dash light does not come on during initial key turn on"
Most likely mean bulb and/or socket is bad.
See my Cave, Lighbulbs
hdryder
Report this Post10-01-2013 05:08 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
This Virginia inspection station claims it should come on during a 'light/circuit' type test with the initial key on.
Is there any DOT or Fed standard for that type requirement in a 1987 vehicle?
The bulb looked good.
I even switched the known working CHECK ENG SOON bulb, into that position, which would not light up when pulling the Emergency Brake lever.
Do the E. Brake switches tend to fail?
[This message has been edited by hdryder (edited 10-01-2013).]
trotterlg
Report this Post10-01-2013 06:08 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, you live in one messed up State. Larry
Report this Post10-01-2013 08:22 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Inspector is correct IF he mean when starting... never in run/on position.
Key turn to bulbtest or start, the light should be on. Any repair book will show you. Brake and a few other warning bulbs work like that on most/all cars since ~1970s.
GM, and many others, ignition switch have these settings.... Accessory, Lock, Off, Run, Bulb Test, Start.
Fiero test Brake bulb and temp gauge from factory. (Many have fix the gauge/bulb "problem" to stop pegging the gauge.)
Some states use private garages to do Safety (and Emissions) Inspections... This is normal in those states. NY and I think PA are in the same boat. Many shops follow the rules...
Doesn't matter on Fed's FMVSS etc because Your state looks for good warning bulb(s).
If you switch w/ a know good bulb and socket...
Circuit "board" on dash, at bulb not making contact or socket for wire plugin to the board.
iffy wire(s)
iffy ignition switch or ground to it. Switch should ground the test bulb in bulb test and start.
Iffy board is a common issue and Not a "Fiero only" problem, Like the socket that wire plugs in likes to have loose copper because glue went bye bye.
Old sockets are a problem too.
[This message has been edited by theogre (edited 10-01-2013).]
Total ratings: 463
Report this Post10-02-2013 06:31 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember reading that the brake light circuit also goes through the chime unit. (aka, blue dingy thingy)
Maybe someone can back me up or knows otherwise...
dobey
Total ratings: 371
Report this Post10-02-2013 09:03 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should ding with the brake on while in run, I think.
I don't know if the chime going bad affects the light coming on though.
Report this Post10-02-2013 09:36 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chime box shouldn't matter for the bulb problem. Leave it out for testing.
Chime activate should be only Park brake is on.
hdryder
Report this Post10-02-2013 12:32 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
My weakness, as far a auto repairs goes, is electrical testing and trouble shooting.
Does anyone have a good, and fairly simple hopefully, procedure I could undertake to trouble shoot the circuit for the E. Brake dash bulb?
Do I want to start at the switch located at the bottom of the E. Brake lever with a circuit test light?
I do have a couple of spare Fiero gauge dashes. Should I swap one of those in early on, or start trouble shooting the bulb circuit?
Report this Post10-02-2013 01:23 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wiggle the bulb socket when someone turn the key to bulb test. socket etc can "wear" even when no moving. Many part here can get damage over time just from constant pressure.
If that helps, carefully bend up the brass contact on the socket. Only a small amount.
check volts at bulb location when someone turn the key to bulb test or start.
Any test light would do.
No volt/light the check the sockets (2) that wire harness go for bent copper traces.
be careful bent copper are easy short out a circuit. You hope your only blow a fuse...
Power likely is not the problem... Power is shared by other bulbs/gauges.
Tan/wht wire on pin 14 big connector (view from front, right connection) is ground when light is on.
Originally posted by jaskispyder:
does it look like this one?
myfiero.oceanmoon.co...gines/700-series-tbi
stole That and other pages (~22 pages) from my cave.
jaskispyder
Total ratings: 205
Report this Post10-02-2013 01:45 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
found it in a google search. Is the cave search friendly?
jimbolaya
Total ratings: 114
Report this Post10-03-2013 08:29 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
More like he needs to find another inspection station in the future. My inspector has never checked anything like this. I'll check, but I don't even think it's on the inspection checklist.
Jim
hdryder
Report this Post10-03-2013 10:29 AM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jim
Jim,
Can you tell me who you use for your Fiero state inspections?
Thanks,
Luke
jimbolaya
Total ratings: 114
Report this Post10-03-2013 12:26 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jim,
Thanks,
Luke
Paul's Auto. It's on Happy Street, just off Bonney Road.
Jim
