  TH125 auto. trans. question
TH125 auto. trans. question by hdryder
Started on: 09-22-2013 09:30 PM
Replies: 2 (164 views)
Last post by: OldsFiero on 09-23-2013 05:39 PM
hdryder
Report this Post09-22-2013 09:30 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can anyone tell me exactly where the top one, of the two fluid tubes, goes inside the transmission?
Thanks for the help.
Report this Post09-23-2013 02:03 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
One is "overflow" from trans main pump, IOW That is bleed/bypass oil output from "pressure regulator"
Other just drains to sump.
Not much pressure on coolant lines.
I had a TSB that said which port is out and in on several trans types but I can find it right now.
OldsFiero
Report this Post09-23-2013 05:39 PM Click Here to See the Profile for OldsFieroSend a Private Message to OldsFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bottom line is hot oil from the torque converter to the cooler. The top line is cooled oil returned from the cooler. It is routed into the internal lube circiut to lube the bushings in the clutch drums,bearings,and geartrain. normal pressures in this circuit are 30-110 psi depending on line pressure.
Marc
