Click here to visit The FieroStore | View all sponsors
  '88 GT, correct location for neg. battery cable to ground?
'88 GT, correct location for neg. battery cable to ground? by hdryder
Started on: 09-22-2013 03:33 PM
Replies: 5 (539 views)
Last post by: uhlanstan on 01-17-2014 08:16 PM
hdryder
Report this Post09-22-2013 03:33 PM Click Here to See the Profile for hdryderClick Here to Email hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can someone tell me where the correct factory ground location is for the negative battery cable on the '88 2.8L V6?
Is it on the passenger side of the front cylinder head, or on the mounting stud bolt for the a/c compressor bracket, possibly?
Do all year 2.8L have the same location?
Thanks for the help.
fierogtlt1
Report this Post09-22-2013 04:42 PM Click Here to See the Profile for fierogtlt1Click Here to Email fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
It is normally attached to one of the 15 mm head bolts holding the ac compressor bracket or the equivalent on the passenger side of the engine.
The smaller wire usually attaches to the body either at the deck lid hinge or directly to the sheet metal beside the battery.
Arns85GT
Report this Post09-22-2013 07:37 PM Click Here to See the Profile for Arns85GTClick Here to Email Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't have too many ground straps. Most Fieros have a ground strap from the front of the block to the passenger side hinge.
I have that one and I added one from the bellhousing to the cradle.
I also put dielectric grease on the terminals to help with corrosion
Arn
jelly2m8
Total ratings: 240
Report this Post09-22-2013 09:03 PM Click Here to See the Profile for jelly2m8Click Here to Email jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Incorrect. OP is correct, all 2.8's have the gruond cable connected at the bank 2 end headbolt with the stud. The smaller guage wire wire is bolted to the battery tray right behind the battery, there are no ' either ' locations from the factory.
Lou and Blue
Report this Post01-17-2014 07:06 PM Click Here to See the Profile for Lou and BlueClick Here to Email Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you please post a picture of the correct location to put the negative from the battery ?
Mine goes to the bracket for the dogbone. Is that right?
Louis Duet
Baldwin, Long Island, NY
"Blue" <= '85 GT
"Gettin' There"
uhlanstan
Total ratings: 427
Report this Post01-17-2014 08:16 PM Click Here to See the Profile for uhlanstanClick Here to Email uhlanstanSend a Private Message to uhlanstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
the dogbone is a bad location ..the main ground should be direct to the engine block,, THE GROUND WIRE MUST CONTACT THE BLOCK..
there should be at least one additional ground from the LOWER block to the FRAME & sub frame(CRADLE) with an additional SMALLER wire to the fender
when you first buy a Fiero you should clean the small ground wire connection,THAT COMES FROM THE BATTERY. a new bright shiney new screw & washer should secure the small ground wire to the fender, TIGHT FIT.IF THE SCREW IS LOOSE INSTALL BIGGER SCREW
on any old car you purchase the main thick ground wire should be cleaned,sanded or wire brushed & the block connection
cleaned bright, this will assure better starting & fewer electrical problems ..
IF THE STARTER SPINS QUICKLY LEAVE IT ALONE, ,JUST MAKE SURE THE NUT IS TIGHT
