  4T60 swap, minor questions.
4T60 swap, minor questions. by 87FieroSport
Started on: 09-20-2013 11:17 AM
Replies: 5 (357 views)
Last post by: hercimer01 on 09-21-2013 01:53 AM
87FieroSport
Report this Post09-20-2013 11:17 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the chance to get a 4T60 for cheap, already includes the axles pre-made.
-Who can I get the shifter
Cable brackets from?
-Is there a write up on how to make changes to the wiring for the Tcc?
I've read Spacecoast,
I'm quite illiterate when it comes to adding circuits. Can't even solder a wire to an LED strip.
87FieroSport
Report this Post09-20-2013 11:24 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also, could this swap be completed in a day?
I have access to a lift and all tools I need.
87FieroSport
Report this Post09-20-2013 07:54 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
87FieroSport
Member since Jul 2012
Guess not
MadMark
Report this Post09-20-2013 10:04 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might want to PM olejoedad about this. He installed one of the 4T60's in my wife's 88 Notchie. He might be able to provide you with at the very least the information.
Grantman
Report this Post09-20-2013 11:01 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
recently did the swap, I wouldn't plan on a day unless you do a lot of swapping and are familiar with it. has the transmission been rebuilt? Are those axles from a pontiac 6000?
The spacecoast article does a good job of showing how to cut and fabricate the brackets (including the one between the motor and trans). although gotta find the stock brackets. Hardest thing to find is the correct governor. I'm glad I found mine from another member.
there are many articles that show adding the pressure switch and doing various wiring. I only used the two wires that ran the 125, cut the wires and spliced them into the 4T60 connector. colors were even the same, although I don't believe all 4T60 used the same color as the 125. I have the ECM controlling the lock up and it appears to be working just fine.
here is another article to refer to, particularly the wiring you ask about.
http://snowcloude.com/~banner/FIERO-4T60.html
1986 Fiero GT Fastback 3.4Lpr with 4T60
1979 Naked Honda Goldwing - sold
1983 Honda Goldwing 1100 Interstate
hercimer01
Report this Post09-21-2013 01:53 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This was my swap.
I would give it a weekend including Friday nite.
https://www.fiero.nl/forum/Forum2/HTML/091761.html
88 Coupe under construction
