  Exact length of an '87 drive axle needed..
Exact length of an '87 drive axle needed.. by Doni Hagan
Started on: 09-18-2013 02:55 PM
Replies: 3 (137 views)
Last post by: Doni Hagan on 09-18-2013 05:46 PM
Doni Hagan
Total ratings: 127
Report this Post09-18-2013 02:55 PM Click Here to See the Profile for Doni HaganSend a Private Message to Doni HaganEdit/Delete MessageReply w/QuoteDirect Link to This Post
The passenger side CV/drive axle on my "87 GT (auto tranny) is dying and I need to swap it out. I was going through my parts stash and found an axle shaft in A1 condition that I must've picked up at one point or another but I'm not certain it's for this car or one of the other Fieros I've had over the years. Before I snatch the bad one off, I need to know if this is the right one. If not, I'll get a correct replacement one before I start the work.
If anyone has a "passenger side CV/drive axle" for a 1987 GT (auto) lying around, could you measure it from end-to-end and post the numbers?
I guess an accompanying pic wouldn't hurt as well, if possible. I'd hate to get the rear end taken apart in my driveway just to discover I need to order an axle.
Thanks in advance, guys!
Report this Post09-18-2013 03:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
That data is posted in spec on autozone.com etc.
Spec is overall length w/ axle compress on tripod.
Auto
P side, 27 1/16 in, 687.4 mm
D side, 21 in, 526 mm
Man
P side, 38 15/16 in, 989 mm
D side, 22 5/8 in, 575 mm
Source: AutoZone
Doni Hagan
Total ratings: 127
Report this Post09-18-2013 05:38 PM Click Here to See the Profile for Doni HaganSend a Private Message to Doni HaganEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Ogre.....
I should've known YOU'D know! Best wishes, guy!
Doni Hagan
Total ratings: 127
Report this Post09-18-2013 05:46 PM Click Here to See the Profile for Doni HaganSend a Private Message to Doni HaganEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doni Hagan
Member since Jun 2001
Well, of the four lengths available, the 27" is the correct one and that's what I've got....minus a couple inches of thread on the end. I must have pulled it off a parts car or grabbed it at a U-Pull lot at some point or another. I honestly don't remember.
Anyway, thanks again!
